405: Rename, New Columns, Stored Search Results
Posted: 12 Nov 2016, 00:54
Rename.
"UPD: Profile List, Source Folder List and Search Result List: Now you can use the hotkey F2 to rename items."
> I don't see that F2 is effective in the Search Result List?
> (Context-menu, Rename does work.)
New Columns.
"UPD: Search Result List: Added the columns 'Duplicates' and 'Search Criteria'."
> I'm not seeing a Search Criteria column?
> Maybe those two items should also show up (as selectable <sp>) in the Columns menu item?
Stored Search Results.
"(!!!): The stored search results of the previous version can't be loaded anymore."
> Could you clarify.
> So, what, existing .asr4 can't be read?
> And is that a (hopefully) temporary issue, to be fixed in later release?
XP SP3.
Rename.
New Columns.
> Could you clarify.
XP SP3.
