Select all files inside the folder structure of this file
Posted: 07 Nov 2016, 03:59
In version 3 when I click "Select all files inside the folder structure of this file" the dialog windo opens with the current folder selected and scrolled into view. In version 4 the folder is selected but if the list of folders is long the selected folder may not be displayed in the window. I have to scroll down to find the folder. Can you autoscroll the folder into view?
