Don't log any file actions
I have the "Don't log any file actions" option checked but all file actions are getting added to the log. Is this a bug?
Re: Don't log any file actions
Seems a log of the search parameters, start & end times,... is (always) maintained (at least for 1 day?).
But actual file deletions (or other actions) are dependent on the settings chosen in the (Search Results) deletion dialog (File Manager) -> Don't log any file actions.
I cant reproduce this problem with the latest beta release.gemnite wrote:I have the "Don't log any file actions" option checked but all file actions are getting added to the log. Is this a bug?
Which version of AllDup do you use and what action did you choose at the file manager?
I use 3.4.24 and the logged action was a file deletion.
