Tip: Combine Folder Dialogs
Posted: 09 Jun 2013, 01:54
Hi,
I just wanted to suggest that the various folder-selection dialogs can be combined:
Figure 1: The Select All Within Folder-Structure dialog has both a folder tree and a direct-enter edit field
Figure 2: The Add Folder dialog needs the direct-enter edit field
Figure 3: The Enter Text + Add Folder dialogs = Folders-Structure dialog (+ check-boxes)
(Also has an inaccurate window title.)
Figure 4: The Edit Folder dialog is identical to the Enter Text dialog; can be combined with Add Folder dialog to create a unified Add/Edit Folder dialog
