A tiny feature request
Posted: 04 Jun 2013, 05:14
Hi there,
AllDup works perfectly from explorer context menu but since my menu is a bit cluttered I spend some time to locate 'AllDup - search for same' entry. I think it would be handier if AllDup puts its own icon in its context menu item- it is always easier to locate an item visually (at least for me).
Anyway, AllDup is an excellent duplicate finder, excellent work, thanks.
