Shortcut Key for Jump to the next expanded group
Heartland
Post by Heartland »
Is there a shortcut key to jump to the next expanded group?
Re: Shortcut Key for Jump to the next expanded group
Not yet. We want to implement ALT+Arrow Up/Down to jump between groups. Im not sure what hotkey will be ok for jump to the next expanded group...any suggestions?
Heartland
Post by Heartland »
Are there plans for making user-configurable shortcut keys? Allowing users to map keys to application functionality would be ideal, but I know that's a lot to ask for.
What do you think about using F4, or F8, or F9 for jumping to the next expanded group?
Heartland wrote:Are there plans for making user-configurable shortcut keys?
Sorry, too many work...we are not lazy but we have many other work to do ;-)
Heartland wrote:What do you think about using F4, or F8, or F9 for jumping to the next expanded group?
The next update will come with this shortcuts:
The key combination ALT + arrow up/down for jumping between groups and ALT + page up/down for jumping between open groups.
