Page 1 of 1
Different totals for drive C showing on main screen
Posted: 06 Jan 2012, 10:51
by rickfr
I just downloaded this software and I'm seeing drive C under the "DRIVES" column showing a total of 288.04 GB and 282.17 used. Yet when I scan drive C and I look at the results under the FOLDERS section on the left I see a total of only 77.57 GB. Why isn't this total amount showing the same total - 282.17 - as under the DRIVES section? I'm trying to figure out why my hard drive is full all of a sudden.
Re: Different totals for drive C showing on main screen
Posted: 06 Jan 2012, 16:43
by Administrator
What windows version is installed at drive C: ?
Posted: 09 Jan 2012, 05:57
by rickfr
Administrator wrote:What windows version is installed at drive C: ?
I'm running Windows Vista.
Posted: 09 Jan 2012, 19:12
by Administrator
It looks like some system folders are not accessable for the GetFolderSize user. Try running GetFoldersize with an Admin account with full system folder access.
Posted: 24 Jan 2012, 10:20
by rickfr
I ended up having to re-install my operating system. I was told that the hard drive was not being read properly by the computer. Everything looks fine now. Thanks for your help!
