Inclusive folder filter bug?
Posted: 16 May 2011, 04:57
Hi,
i have similar problem with folder filter.
1) set the folder filter mode to "Inclusive".
2) deselect the default folders used to be excluded (\system volume, \windows etc etc)
3) add two new folders with a subfolder each
S:\DanyToCheck\Applications\Admin Utility\SysInternals\AccessChk
S:\DanyToCheck\Applications\Admin Utility\SysInternals\AccessChk\2.0
S:\Incoming\Applications\Admin Utility\SysInternals\AccessChk
S:\Incoming\Applications\Admin Utility\SysInternals\AccessChk\2.0
The subfoders contain only and only one file: accesschk.exe
The file is the same on both subdirs.
I selected the confimation on use filter in the options.
The FILE filter is configured as the default: inlcusive with no item selected.
OK, now press the button "Start Search" and answer yes to the following dialog:
AllDup
Use file and folder filter with this search?
Yes No
The answer of the search was:
AllDup
1 folders and 11 files were search but no duplicates were found.
OK
One folder???!
(there were 4)
11 files???
(there were 2 in total)
How does it work?
I can't understand it. Can anyone help me?
Moreover, if you deselect ALL the selected folders in the "Inclusive" mode, and then click on "Start Search", it will start the search on the entire drive instead of alerting me there is no folder selected!!!
Very strange behaviour....isn't it?
Thanks for your attention.
Bye
Daniele
AllDup
Yes No
AllDup
OK
One folder???!
11 files???
How does it work?
Bye
Daniele
