Page 1 of 1
Feature Suggestion
Posted: 30 Oct 2010, 03:14
by donny
New action to perform on selected duplicate files:
Replace duplicate file with an empty placeholder. The name could be set by the user and special tags would be replaced by AllDup.
Example configuration:
Deleted Dup <DATE_DELETED>-<TIME_DELETED> <FILENAME>.<FILEEXT>
Physician Report.docx would become
Deleted Dup 20100216-142523 Physician Report.docx
Re: Feature Suggestion
Posted: 01 Nov 2010, 16:55
by Administrator
I added "Setting the file size to zero and rename the file" to our ToDo-List.
Posted: 13 Nov 2010, 07:49
by donny
Thanks for getting this feature into the application so quickly!
If I change the name or check "Set file size to zero" it is reset back to the default when I close and re-open the window again. Should it be retained?
Posted: 13 Nov 2010, 15:14
by Administrator
Thanks for the hint. The settings will be saved with the next update. Drop me a email for a new update if you need the fix now.
Posted: 14 Nov 2010, 15:04
by donny
Thanks for the fast response! I can wait for the next update to get this fix.
The design of the feature is sufficient for me, but I think others might want a little more safety. If they mistakenly zero out a file there isn't a way to recover. Should the original file be moved to the recycle bin?
Posted: 05 Feb 2012, 06:56
by donny
Set file size to zero doesn't work for me in 3.3.25.
Posted: 06 Feb 2012, 15:37
by Administrator
I think we found the problem. Do you have activated the option "Don't log any file actions"?
Posted: 08 Feb 2012, 01:45
by donny
Thanks for the fast response. You are right. I do have the option activated.
Posted: 08 Feb 2012, 03:13
by Administrator
This problem will be fixed with the next update. Please turn off the option until the next update will be released.
