Page 1 of 1
Feature Request: Compare with External Application
Posted: 21 Sep 2010, 11:25
by corinthianclock
I want to select two files and pass them to an external application for processing or comparison. The implementation would simply launch an application passing it the two selected files.
Re: Feature Request: Compare with External Application
Posted: 23 Sep 2010, 15:00
by Administrator
We have note your suggestion to our ToDo-List for upcoming releases.
Posted: 24 Sep 2010, 17:06
by Administrator
Your feature suggestion was added. Please send me a email if you want to test the new feature.
Posted: 03 Oct 2010, 03:33
by corinthianclock
This is fantastic! The setting is even saved in profiles, so if you had more than one application you can switch profiles. Thanks! This is the best dupe finder I've ever used!
Posted: 30 Oct 2010, 02:26
by donny
I agree, this is the best dupe finder available! I love this new feature. Would the developer consider adding multiple compare applications? I have several that I want to use and prefer not to change profiles and rerun a compare each time to switch. Many thanks to the developer(s).
Posted: 01 Nov 2010, 16:49
by Administrator
I have noted your suggestion to our ToDo-List. Thanks for the feedback!
