Feature Suggestion
corinthianclock
Feature Suggestion
Post by corinthianclock »
I love AllDup! A feature I'd like added is the ability to double click results to cause actions to occur. Double-clicking the filename would open the file with the default applicaton. Double-clicking the path name would open the folder in Explorer. Maybe even make it configurable so the actions could be changed?
Thanks for a great product!
Re: Feature Suggestion
I will note this on our ToDo-List for the next update!
corinthianclock
Thanks!
