Page 1 of 1
Create shortcuts or hardlinks to the last original file
Posted: 18 May 2010, 21:33
by abrenden
"Create shortcuts or hardlinks to the last original file". This text is from the help menu in AllDup version 3.0.2. I am not able to find this option anywhere. Is it not implemented yet?
Re: Create shortcuts or hardlinks to the last original file
Posted: 19 May 2010, 00:06
by Administrator
On the menu bar, click the "Search Result" menu, and select the "Delete, copy, move or..." menu item. Now check the options at the new window.
Posted: 19 May 2010, 15:01
by abrenden
Thanks. That works fine.
Posted: 05 Jun 2013, 08:31
by stevenfoo
Administrator wrote:On the menu bar, click the "Search Result" menu, and select the "Delete, copy, move or..." menu item. Now check the options at the new window.
I wonder why I tried the newly downloaded version but it did NOT create a hard link with option delete files in place.
The hard link was not created at all in my windows 2003 SP2 server.
If I use shortcut, it is working fine.
Posted: 05 Jun 2013, 13:05
by Administrator
The hdd must be formatted with NTFS. There is a windows service called "TrkWks":
http://searchtasks.answersthatwork.com/ ... ile=TrkWks
Maybe this service should be running.
