Posted: 07 Jun 2012, 01:57
I am currently using 3.4 and "Select all files inside the folder structure of this file" only allows me to select subfolders. Is the ability to select parent folders going to be added back in a future release?
Support Forum
https://www.allsync.biz/phpBB/
I hope so. I went back to 3.2 because of it.britd wrote:I am currently using 3.4 and "Select all files inside the folder structure of this file" only allows me to select subfolders. Is the ability to select parent folders going to be added back in a future release?
Just use "Select all files inside the following source folder" and select the folder you want.britd wrote:I am currently using 3.4 and "Select all files inside the folder structure of this file" only allows me to select subfolders. Is the ability to select parent folders going to be added back in a future release?
