Error #1053 when starting Service
dar
Post by dar »
I am trying to get the scheduler to run whilst logged off.
The service would not start either form the Service Tool or the Service Console.
I uninstalled and reinstalled the Service Tool as as well as ALLSYNC itself. I rebooted after the uninstalls as well. All to no avail.
Can someone please help?
Re: Error #1053 when starting Service
The error 1053 can appear when the scheduler is activated. Please exit the scheduler and try it again with the service tool. Also check the file service.log for some informations about the error.
dar
Post by dar »
Administrator wrote:The error 1053 can appear when the scheduler is activated. Please exit the scheduler and try it again with the service tool. Also check the file service.log for some informations about the error.
I exited the scheduler and even checked to see if had left behind any remnants using Process Explorer (from Systernals). When trying to restart the service, either from the TOOL or the Services MMC, I get the saem error.
Here is the service.log.
6/23/2005 5:01:00 PM - No license information could be found.
6/23/2005 5:01:31 PM - No license information could be found.
6/23/2005 7:20:41 PM - No license information could be found.
6/23/2005 7:21:05 PM - No license information could be found.
6/24/2005 12:06:29 PM - The service has been successfully uninstalled.
6/24/2005 12:07:08 PM - AllSync Scheduler has been successfully installed as a service.
6/24/2005 12:07:20 PM - The service has been successfully uninstalled.
6/24/2005 12:07:42 PM - AllSync Scheduler has been successfully installed as a service.
6/24/2005 12:07:44 PM - No license information could be found.
6/24/2005 12:07:53 PM - No license information could be found.
6/24/2005 12:07:58 PM - The service has been successfully uninstalled.
6/24/2005 12:14:03 PM - AllSync Scheduler has been successfully installed as a service.
6/24/2005 12:14:05 PM - No license information could be found.
6/24/2005 12:18:06 PM - No license information could be found.
6/24/2005 12:18:28 PM - No license information could be found.
6/24/2005 12:21:26 PM - No license information could be found.
6/24/2005 12:21:35 PM - No license information could be found.
6/24/2005 12:21:48 PM - No license information could be found.
6/24/2005 12:24:36 PM - No license information could be found.
6/24/2005 12:24:52 PM - The service has been successfully uninstalled.
6/24/2005 12:25:22 PM - The service couldn't be uninstalled.
6/24/2005 12:33:09 PM - AllSync Scheduler has been successfully installed as a service.
6/24/2005 12:33:25 PM - No license information could be found.
6/24/2005 12:33:50 PM - No license information could be found.
6/24/2005 12:37:23 PM - No license information could be found.
6/24/2005 12:55:12 PM - No license information could be found.
Thanks!
The scheduler service quits because no license information could be found. I think the used "User Account" for the service have not enough rights. Which account do you use for the service? Admin?
dar
Post by dar »
Yes. Admin. I also tried 2 other accounts that have Full Admin rights.
Please know that the message occurs very quickly, e.g. 2-3 seconds. Normally for a incorect user, this takes much longer to time out.
Maybe you installed AllSync via "user A" and now you want to start the scheduler service via the account of "user B". But "user B" dont have enough rights to check for the license of "user A" on your system.
Try installing and starting the service with the user account you have used to install AllSync.
dar
Post by dar »
That is not the case. Allsync was installed under account A. I used Account A to install and start the scheduler.
Is there a way to use the Windows Task Scheduelr and command line to run AllSync automatically? If yes, is it possible to have AllSYnc send the email notice when it runs under Windows Task Scheduler?
There must be a reason why the scheduler service have no access to the registry...
You can use every task scheduler you prefer for scheduling. Please use the Shortcut Manager of AllSync to create the command line.
No, this is only available with the Allync Scheduler. Why don't you use the AllSync Scheduler? You don't have to run it as a service...or?
dar
Post by dar »
How can AllSync run then if I am not logged on? This is a remote server. Please tell me how to make the Scheduelr run without it being a service.
Could this have anythign to do with the problem?
My ini file reads:
[Allgemein]
Lang=9
Dateiname=AllSync
Version=2.6.0
Programmtyp=Demoversion
User=?
Registriert=0
What about a complete uninstall and reinstall?
Ok, if your not logged on, you need to run the scheduler as a servie...
My ini file reads:
[Allgemein]...
No.
Maybe, but i dont think this would help.
The message "No license information could be found" at the logfile of the service means, that the used account for the scheduler service dont have enough rights to check for the necessary license information of AllSync. Please check the user rights of your used account for registry access. If the used account cannot retrieve the information from the registry the service cant startup.
Do you use a local admin account for installing the service?
