It would be nice to add an option to make a .bat file to restore changes later (copying the file left) or show the log in a way to do it easily.
Regards.
Feature Suggestion
Re: Feature Suggestion
When you move the files to a backup folder AllDup should create a batch file inside this backup folder to restore/copy back all the files automatically?
I mean copying the file(s) that was/were not erased. (After decompressing a bunch of files, for example)
copy "data\template\overlay\pl_r_nomrt.vpc" "data\template\overlay\pl_r_spec_nomrt.vpc"
copy "data\template\overlay\pl_r_nomrt.vpc" "data\template\fz_overlay\pl_r_spec_nomrt.vpc"
