Estimated Time to Completion
Heartland
Post by Heartland »
Can AllDup display the estimated time to completion while searching?
Re: Estimated Time to Completion
Its easy to show the time of completion if you copy a file from A to B. If you search for duplicates there are no fix values to determine the time to completion. Sorry.
Heartland
Post by Heartland »
I think you can get a rough estimate after a few seconds because you already show duration and the progress as a percentage. The estimated time to completion is:
TimeLeft = ElapsedTime/PercentCompleted - ElapsedTime
If the progress is at 15% and the duration is 45 seconds then the time left is 4:15.
45/.15 - 45 = 255 seconds = 4 minutes and 15 seconds
If you keep recalculating periodically, the estimate will get more accurate as the progress approaches 100%.
I dont want to show a very rough estimated time to completion. The current progress is calculated by the the maximum file count. Up to the search criteria and options there are so many different comparing actions for each single file. Some files need many comparing other files not. The estimated time to completion will not be helpful because the showed time is not real. If i copy a file from A to B i want to see a real estimated time to completion but the search for duplicates is to complex and unpredictable to show this time.
