wildcard not working in exclusive folder filter?
mdeck
Post by mdeck »
Hi,
I'm on Win7-64, AllDup 3.3.14, just installed last night for the first time.
"Use File Filter" is not checked.
"Use Folder Filter" IS checked; radio button is set to "Exclusive"; all filters are checked; no options are checked (not "ignore wildcards" and not "case insensitive").
One of my filters is a wildcard:
?:\AppData
so it doesn't look in any user's c:\users\<name>\AppData folder.
At least, that's the theory. It looks in those folders every time.
(Note that I can specify each of the folders directly and that works fine, but that rather defeats the purpose of having the wildcard in the first place. :)
-- mdeck
Re: wildcard not working in exclusive folder filter?
"?:\AppData" doesnt match with "c:\users\<name>\AppData". Just use the folder filter text "appdata".
mdeck
Post by mdeck »
From help:
When a filter text contains a backslash (\) comparison is made with the entire path of the current folder.
which says to me that "?:\AppData" should match "<anydrive>:\<anypath>\AppData" (e.g., "c:\users\<name>\AppData").
If that's not the case, it could be made clearer in help.
And I request that as a feature. :)
So that means that the included-by-default filter "?:\Favorites" doesn't do anything, huh? (As far back as I can remember with Windows -- and I go back to 3.1 -- "favorites" have always been associated with a username, so they'd never be at the top level of a drive's filesystem.)
-- mdeck
A backslash (\) is NOT a placeholder for <anypath>. If you use "?:\AppData" the folder AppData must be on the root of any drive.
I dont know why the the "?:\Favorites" is included at your folder filters.
AllDup only adds the enviroment variables "windir" & "ProgramFiles" and the hard coded folders "System Volume Information" and Recycle Bin folders to the folder filter list.
