select all but largest/smallest
FrizzleFry
Post by FrizzleFry »
In the search results toolbar there are buttons labeled:
Select all files except the smallest file
Select all files except the largest file
Do these refer to the size of the files or length of the filenames?
Re: select all but largest/smallest
These buttons refer to the size of the files.
FrizzleFry
Ok, that makes sense... but not very useful to me since most of my searches are on content :)
It would be nice to get buttons to select longest or shortest filenames because many dups are the result of auto-renaming.... either as
copy of filename.ext
or
filename-(0001).ext
ok, i will note your suggestion on our ToDo-List.
