I love that AllDup is able to ignore the ID3 tags of MP3 files; that sets it above almost all other duplicate-file-finders
However there are other metadata tags that can easily be changed and cause two otherwise identical files to appear to be different, especially since newer OSes like Windows 7 make it so easy to modify the tags. Here are a couple of common ones:
- Exif data for picture files like JPG
- Metadata for Microsoft Office (specifically Word) files
It would be great if AllDup could have an option to ignore them to weed out other duplicate multimedia files.
Thanks a lot.
