Right now I'm using the commands from here to start alldup https://www.alldup.de/alldup_help/commandline.php with the folders and options I want it to check
Is it possible to script the following:
1. run the compare (already can using command line)
2. run 'select all the files with the shortest name'
3. run process selected files
4. then exit
automate run
Re: automate run
No, thats not possible. You can use the tool "AutoIt" to automate user inputs for example.
