When I do a search, does Allup return all files groups within my search parameters that contain duplicates - plus the originals?
So when I go to delete the duplicates, I should retain at least one file in each group as one is likely to be the original?
In "File Manager", should I tick "Do not process groups with all files selected" because one file in every group is likely to be an original?
Many thanks in advance
