Find similar pictures between 2 source folders not working?
dlflemingos
Post by dlflemingos »
I found this feature to be most helpful in finding duplicate photos. It cuts down on the run time and tells me which new downloaded picture files are redundant but now it doesn't seem to be working.
Using between 2 source folders finds no duplicates. If I switch to search all folders it will find many duplicates but I specifically only want to see between the new folders. I moved one directory to another drive and no luck. I put a test .jpg file in each directory I'm comparing and it doesn't find them.
This is a great feature, what is the trick to getting it working again?
I just updated from 4.5.46 to 4.5.48 and then noticed it wasn't working.
Re: Find similar pictures between 2 source folders not working?
Did this feature worked correctly with 4.5.46 and after updating to 4.5.48 it stop working?
dlflemingos
Either that or I started doing it wrong.
I cant reproduce this problem:
02.08.2023 13:24:43 - AllDup 4.5.48
02.08.2023 13:24:43 - Search method: Find similar pictures
02.08.2023 13:24:43 - Comparison method: dHash
02.08.2023 13:24:43 - Image Formats: 3FR, ARW, BMP, CR2, CRW, CUT, DCR, DNG, ERF, GIF, HDP, ICO, IFF, J2C, J2K, JP2, JPEG, JPG, JPX, KDC, MDC, MEF, MOS, MRW, NEF, ORF, PBM, PCX, PEF, PGM, PNG, PPM, PSD, RAF, RAS, RAW, RW2, SRW, TGA, TIF, WBMP, WEBP, X3F
02.08.2023 13:24:43 - Match: 95%
02.08.2023 13:24:43 - Picture area: entire picture
02.08.2023 13:24:43 - Comparison size: 16x16 Pixel
02.08.2023 13:24:43 - Checksum Strength: 256 Bit
02.08.2023 13:24:43 - 1.Source folder: C:\test\pics1
02.08.2023 13:24:43 - 2.Source folder: C:\test\pics2
02.08.2023 13:24:43 - Option: Compare only files between different source folders
02.08.2023 13:24:43 - Determine file count of all source folders...
02.08.2023 13:24:43 - File count: 2
02.08.2023 13:24:43 - Scan: C:\test\pics1
02.08.2023 13:24:43 - Scan: C:\test\pics2
02.08.2023 13:24:43 - Found 1 duplicates with a total of 43,84 KB inside folder 'C:\test\pics1'
02.08.2023 13:24:43 - Found 1 duplicates with a total of 43,84 KB inside folder 'C:\test\pics2'
02.08.2023 13:24:43 - Scanned files: 2
02.08.2023 13:24:43 - Groups: 1
02.08.2023 13:24:43 - File comparison count: 1
02.08.2023 13:24:43 - Checksums created: 2
02.08.2023 13:24:43 - Duplicates: 2 (100%) (87,68 KB)
02.08.2023 13:24:43 - Elapsed time: 00:00:00
dlflemingos
Thanks. Before I went to bed last night, I started 4 scans for comparison.
Then as I was brushing my teeth realized that I needed to run a controlled test case.
The 4 big scans (10,000/folder) did as expected but I had cleaned up most of the duplicates and had to turn the match down to 85% and things gets messy when I do that (with false matches).
The small test cases I did this morning also worked as expected and the different source folders gives me what I want (sorting new incoming pictures to my vetted pictures). However, the different source folder comparison did more comparisons and took longer which is surprising.
But, on the big scan the between folders took ~1 hour and all folders took ~3hrs as expected. The between folders option works great.
