Display Search Method in the Titlebar
That would be nice.
as it is, i'll change between various search methods, depending...
typically, the first thing i'll do is to add my directories
once added, i could then immediately search - but,
at that point, i am unsure which Search Method had been
selected, prior, so i then need to specifically click the
Search Method to verify
- if at least the Method displayed in the Titlebar, a quick
glance show's that Content is enabled, & i can then say,
"ah, that's what i want",
& simply hit "GO" at that point
(Now granted, knowing that Content, or whatever, is what was the last setting used was, may not be "enough" for a particular task, but at least you're clued in without having to specifically look further.)
Re: Display Search Method in the Titlebar
I will note this on the ToDo-List.
