Removing duplicate mp3 files
I've searched and found a number of duplicate mp3 music files. How do I select and delete the duplicates only. I'd like to be able to delete all at once.
Re: Removing duplicate mp3 files
Please check out the Select section at the main menu bar.
Here you will find a lot of different commands to select files at the search result.
