errors on start of all Dup
ChrisMil
Post by ChrisMil »
Since now I have been running 4.0.20 version of AllDup with no problems
I have installed version 4.0.47 a few day ago and I have several errors on start
- Run-time error '429' : ActiveX Component can't create object
I click OK and a second time the same error
I click OK again and it is follow by
- Run-Time error '440' : Automation error
I click OK again and nothing happens
Please help
Christophe
Re: errors on start of all Dup
What windows version do you use?
ChrisMil
Post by ChrisMil »
I use Windows 7 pro 64bit SP1
We already tested AllDup 4.0.47 (Installer & Portable) with a fresh installed win7x64 and everything runs fine here.
Please do the following test: extract the portable edition of AllDup into a folder on your desktop and start AllDup.
Does this work without any problems? If not it must be a system specific problem of your computer...
ChrisMil
Post by ChrisMil »
So i have tried many thing to solve this problem
I have Re install the 4.0.20 version of alldup and it's working perfectly but the 4.0.47 still cause problem.
is there a difference of Library, component or else not provided in the 4.0.47 package but present in the 4.0.20 ?
Thx
as i already mentioned before - AllDup v4.0.47 runs here without any problems at a fresh installed win7x64.
It looks like that something system specific at your computer causes this problem.
Did you already have done the test with the portable edition as described before?
