Solved: Ignore Dupes Within a Set
johnywhy
Post by johnywhy »
Scenario:
I have 3 sets of backups.
Set 1: G:\Stuff\Files\many folders\many files
Set 2: G:\Files\many folders\many files
Set 3: G:\many folders\many files
If i add them as 3 sets, i want to ONLY find dupes between the sets.
But AllDup finds dupes within a set. Example:
G:\Files\XYZ\banana
G:\Files\ABC\banana
Even those two are in the same set (Set 2), they are listed as dupes. I want to ignore dupes like this, in the same set, and only show dupes between different sets. Example:
G:\Stuff\Files\XYZ\banana
G:\Files\XYZ\banana
Re: Request: Ignore Dupes Within a Set
Add the 3 folders as source folders and activate the source folder option "Compare only files between different source folders".
johnywhy
Post by johnywhy »
Thx!
