Rename File (from within Results Window)
F2 (or user assigned hotkey to) Rename a File (from within the Results Window).
I'm not recalling, is that feature not there?
If not, RFE :-).
(Windows Explorer | Properties isn't particularly viable - for me.)
Re: Rename File (from within Results Window)
The context menu command "Rename File" will be available with the update after v4.0.3.
