Select all files inside the folder structure of this file
I use "Select all files inside the folder structure of this file" all the time. It is very convenient. Often I need to go up a directory or two, so I just delete the subdirectories I don't want.
In Windows Vista and Windows 7 the address bar has clickable navigation.
http://windows.microsoft.com/en-US/wind ... ddress-bar
I am wondering if AllDup could make the folder structure field clickable like Window's address bar?
Re: Select all files inside the folder structure of this fil
We will replace the current input box with a folder tree:
![Image](http://www.ssware.com/fldrview/shots/main.jpg)
I think a single line address bar is more appropriate for this since I'm right-clicking a file and starting with a path, I should only be allowed to select a parent folder--not a folder on another drive. The folder tree takes a long time to populate, so a benefit is that the single address bar is going to be much faster to display and be easier to select a parent folder. The tree requires some scrolling which slows me down further. Also, you could populate the address bar with the selected path so if a subfolder is deleted outside of AllDup, the path can still be presented allowing selection of a parent folder.
Thanks for the consideration.
I agree that the new (3.3.0.25) folder dialog is not practical. It’s a nice feature, but currently does not work well enough to make it worth while.
If there are a lot of folders, then Alldup can hang for a minute or two with 100% CPU while the folder dialog populates. The old way was slightly less convenient, but much faster.
Also, moving the mouse cursor over it flickers really badly.
I would prefer the text box, with the option of using wildcards. For example, more helpful than the folder dialog, would be to let the user enter something like this:
?:\foobar\blah*\stuff
This could be fixed if we turn off the tooltip feature for the node items.Also, moving the mouse cursor over it flickers really badly.
How to reproduce this problem? If i add a new source folder and populate first C: and next C:\Windows and next C:\Windows\system32. Everything populate fast and dont hang. I use here a Vista PC with a old Intel CPU Core2Duo 2,26GHz.Synetech wrote:If there are a lot of folders, then Alldup can hang for a minute or two with 100% CPU while the folder dialog populates.
Like britd said, it happens with slow disks/discs or network folders, but having a lot of folders in a lot of folders (ie, lots of folders nested deeply) also does it.
Also, having an old, slow system certainly helps (uh, I mean hurts). I’m using a P4 1.7GHz which takes 1-2 minutes if I scan my big dump folder (where I keep all of the files I have downloaded from the Internet over the years and try to sort into subdirectories).
I’ll try to record a screenshot, but that will probably just slow it down even more.
Okay, I recorded a screenshot, but it stutters a lot (my system is too slow to record in real-time), so it ends up only ~30 second (a lot of dropped frames), but the actual time is ~1 minute.
Sorry, the video dont run. No access or so...
I can replace the new dialog with an alternative folder dialog. I prefer to let the user choose the dialog by an option. Drop me an email if you want to test alternative dialogs at your slow pc.
