Problem 1:
I populate the source and destination panels with folders. However, it won't let me check more than one folder in the G: destination panel.
[x] D:\My Movies [x] G:\My Movies
[x] D:\My Mailbox [ ] G:\My Mailbox
When I do a copy preview, it adds all the D: source folders as SUB-folders of G:\My Movies:
G:\My Movies\My Movies, G:\My Movies\My Mailbox
Instead of separate folders:
G:\My Movies, G:\My Mailbox
Problem 2:
For the Test1 profile, I go to "Profile Properties", "Options", "Scheduling" and check "Upon completing the processing of the profile - Shut down computer".
I click "Apply".
But when I run it, it won't shut down when it finishes.
And when I go back to the "Upon completing...... " option, it is no longer checked.
What am I doing wrong?
Dimitri
multiple destination folders & auto shutdown problem
Problem 1 solved by specifying just "G:\" as the destination folder.
Problem 2 still pending. I'm able to specify an external program (a shutdown.bat script) that is launched by AllSync upon copy completion, but that doesn't explain why the internal shutdown feature of AllSync is failing.
Dimitri
Dimitri
Re: multiple destination folders & auto shutdown problem
[quote="Dimitri]But when I run it, it won't shut down when it finishes.[/quote]
Do you run the profile manually or automatically via the scheduler? This option only works fi the profile is started automatically via the scheduler.
profile changes not saved?And when I go back to the "Upon completing...... " option, it is no longer checked.
