Running Allsync as a Service
mtn_roadie
Post by mtn_roadie »
win2k server
Allsync 2.2.18 business edition
I have been unable to set up the service tool to run scheduled backups. This is what I've done to date:
1. Installed the service tool per the help docs.
2. Registered the service under my user account.
3. Started the service.
4. Selected the option in the scheduler to run on startup.
The service/scheduler will work when I have the backup copy files to the same machine Allsync is installed on. However, I am unable to copy files to a drive on the network, unless I have the scheduler open when I'm logged into the system.
Here is a sample of the log - everything was run when I was logged into the system:
1/12/2005 5:46:58 PM - AllSync Scheduler 2.2.18 activated.
1/12/2005 5:47:00 PM - ==================================================
1/12/2005 5:47:00 PM - Copy operation started
1/12/2005 5:47:00 PM - PROFILE: two
1/12/2005 5:47:00 PM - COPY MODE: 1:1 copy
1/12/2005 5:47:00 PM - --------------------------------------------------
1/12/2005 5:47:00 PM - SOURCE: C:\www\xroubaix\clients\_ftp\
1/12/2005 5:47:00 PM - ERROR: The destination folder 'F:\test\' couldn't be found: (#3 - The system cannot find the path specified.)
1/12/2005 5:47:00 PM - PROFILE-STATISTIC:
1/12/2005 5:47:00 PM - Elapsed time: 0:00:00
1/12/2005 5:47:00 PM - No changes were made during the copy operation.
1/12/2005 5:47:00 PM - Copy operation complete.
1/12/2005 5:47:00 PM - NOTE: Some errors have occurred. Note the 'ERROR' message(s) in the log.
1/12/2005 5:47:00 PM - INFO: 1 of 1 license(s) have been used since starting AllSync.
1/12/2005 5:47:00 PM - DESTINATION: F:\test\
1/12/2005 5:47:00 PM - Processing: source --> destination
1/12/2005 5:47:01 PM - Files created: 1
1/12/2005 5:47:01 PM - Folders created: 22
1/12/2005 5:47:01 PM - Data volume copied into the destination folders: 3.11 KB
1/12/2005 5:47:01 PM - --------------------------------------------------
1/12/2005 5:47:01 PM - Copy operation complete.
1/12/2005 5:47:01 PM - INFO: 1 of 1 license(s) have been used since starting AllSync.
This is what I'd like to achieve:
1. Have Allsync run my back up routines when I'm not logged into the system.
2. Have the files copied to a drive in the network.
I think I may be missing something quite obvious here, but I have been unable to solve this problem.
Thank You,
Kindler Chase
Re: Running Allsync as a Service
user account = adminstrator
maybe the folder F: is only availble if the user is logged on. try using the real network path like \\computername\test at the profile properties.
if u autostart the scheduler as a service (3.) and as a normal program (4.) u may run into problems, because u start the scheduler twice.
please turn off autostart for the scheduler at the options.
mtn_roadie
Yes, user account is an administrator.
OK - that seems to work. I'm running some extended tests to ensure everything is functioning as expected.
Done (turned off the autostart). What is the purpose of having the scheduler autostart?
I'll post back when all the tests are complete.
Scheduled profile running without the service? ;-)
mtn_roadie
Thanks for the help. The service appears to be running smoothly now. I do have some questions about the email options that I'll post under a separate topic.
