During the scheduled sync procedure, I got an error message (below).
1. Am I correct in understanding that the problem lies on the destination computer?
2. Considering that the application that is associated with this files is not un use on source or destination at the time of back up procedure, I do not know why these files would be in use. Is there any software that you can recommend that would analyze the files currently in use and tell me what is using these? Also is there way to restart a computer BEFORE running the AllSync application? Is there something else I can do to prevent this problem from happening, and to ensure that the automated back up procedure goes on as scheduled and STAYS AUTOMATED, without me manually adjusting anything every time before back up and be certain of reliability of the procedure?
ERROR DESCRIPTION:
xxxxxxxxxxxxxxxxxxxxxxxxxxx
11/6/2005 1:00:01 AM - ==================================================
11/6/2005 1:00:01 AM - Task 'Backup Skyline Data from OFFICE to HOME' started
11/6/2005 1:00:01 AM - PROFILE: Backup Skyline Data from OFFICE to HOME
11/6/2005 1:00:01 AM - COPY MODE: User-defined copy
11/6/2005 1:00:01 AM - --------------------------------------------------
11/6/2005 1:00:01 AM - SOURCE: F:\SKYLINE\
11/6/2005 1:00:01 AM - DESTINATION: C:\SKYLINE\
11/6/2005 1:00:01 AM - Editing source --> destination
11/6/2005 1:00:15 AM - ERROR: Error while moving file 'C:\SKYLINE\DATA\Ardetail' to the Recycle Bin.
11/6/2005 1:00:25 AM - ERROR: CopyFile2: CreateFile: #32 - The process cannot access the file because it is being used by another process. (F:\SKYLINE\DATA\Ardetail -> C:\SKYLINE\DATA\Ardetail)
11/6/2005 1:00:45 AM - ERROR: Error while moving file 'C:\SKYLINE\DATA\GLINTER' to the Recycle Bin.
11/6/2005 1:00:46 AM - ERROR: CopyFile2: CreateFile: #32 - The process cannot access the file because it is being used by another process. (F:\SKYLINE\DATA\GLINTER -> C:\SKYLINE\DATA\GLINTER)
11/6/2005 1:00:53 AM - ERROR: Error while moving file 'C:\SKYLINE\DATA\OCCUPANT' to the Recycle Bin.
11/6/2005 1:00:54 AM - ERROR: CopyFile2: CreateFile: #32 - The process cannot access the file because it is being used by another process. (F:\SKYLINE\DATA\OCCUPANT -> C:\SKYLINE\DATA\OCCUPANT)
11/6/2005 1:01:06 AM - ERROR: Error while moving file 'C:\SKYLINE\DATA\TRAN' to the Recycle Bin.
11/6/2005 1:01:06 AM - ERROR: CopyFile2: CreateFile: #32 - The process cannot access the file because it is being used by another process. (F:\SKYLINE\DATA\TRAN -> C:\SKYLINE\DATA\TRAN)
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Oleg Vishnevetski
Re: cannot access the file because it is being used by anoth
Sorry for the late response. After updating the web forum to a newer version the message notifier doesnt worked correct.
The freeware tool "Handle" from SysInternals: http://www.sysinternals.com/utilities/handle.html
Yes, the destination file is locked for write access by any processes.Am I correct in understanding that the problem lies on the destination computer?
You want to restart the destination computer on the network?Also is there way to restart a computer BEFORE running the AllSync application?
If a file has been locked by another application or the system for write access there is nothing you can do. Only the app that locked the file can release the lock.Is there something else I can do to prevent this problem from happening
Q: Also is there way to restart a computer BEFORE running the AllSync application?
A: You want to restart the destination computer on the network?
Q: I want to be able to restart the destination computer. This is a computer on which the AllSync is installed. There some other applications that I know of that would allow you to retsart the computer BEFORE they are run. They will run DURING or AFTER the restart.
Is there such feature in AlSync? Can you add it in the new realese? Can it be incorporated in the sceduler?
Oleg Vishnevetski
intramanga
Came across this post looking at your forum.Administrator wrote: If a file has been locked by another application or the system for write access there is nothing you can do. Only the app that locked the file can release the lock.
Actually there is a solution for this , have a look here : http://www.vwsolutions.com/productInfor ... roductId=3
Using this as a trial and it seems to work with my other backup software, so i guess it will work with yours as well
Ed,
Thanks for the feedback. We also have listed this solution at our Software Recommendations: http://www.allsync.de/help/t_fremdtools.htmintramanga wrote:Came across this post looking at your forum.
