http: (not https:) login does not work
Hier können alle Themen diskutiert werden, für die kein passendes Forum vorhanden ist.
http: (as opposed to https:) login (seemingly) does not work.
That's fine, except I happened upon a http:// link & when I went to log in,
I received a, "The submitted form was invalid. Try submitting again.", message.
And that was confusing (as I had thought I entered my correct un/pw).
So I tried a different browser, copying the URL over from 1 to the other, & as the copied URL was http:, I ended up in the same circumstance, "The submitted form was invalid. Try submitting again.". So then I check (browser) History, & recent has been https: & that clued me in.
On the https: end, I was able to successfully log in.
Maybe if one inadvertently ends up on a http:// page, if it rolled over to https:// (or at least for the login procedure), that would have been less confusing.
Re: http: (not https:) login does not work
I cant reproduce this problem because the web server automatically redirects a http-request to "https".
for example:
http://www.allsync.biz/phpBB/index.php
redirects to
https://allsync.biz/phpBB/index.php
