Can't use {Enter} to open the file location
undupit
Post by undupit »
It seems I can't use {Enter} anymore to open the file location, in the newest version of AllDup. Assigning that hotkey to 'File actions: open file location' doesn't work. It did work in an older version.
I hope you can bring that option back.
Re: Can't use {Enter} to open the file location
How do (did) you go about assigning <Enter> to be the hotkey?
Oh, that's how.
In earlier versions, you simply hit <CR> (the same as any other key you might want to use).
In 4.5.72, that (hitting <CR>) no longer works.
In 4.5.72, you can work-around it...
Exit AllDup.
(Backup first.)
Edit config4.ini.
In the, [Shortcuts], section
add (or modify, as appropriate) the following:
ID0=313,
Key0=Enter
That should get you back working again.
