Run-time error '440'
undupit
Re: Run-time error '440'
Post by undupit »
Administrator wrote: 08 Jul 2019, 18:02 We have done another test with AllDup 4.3.12 Beta on a fresh installed Win10 Pro v1903 PC and everythings runs without any errors...
I get the same error, when doing a large compare (not if I cut the compare in small pieces), but after error 380:
https://www.allsync.biz/phpBB/viewtopic.php?t=2747
Using 4.5.38 PE.
To be clear, you're getting both 380's & 440's ?
And here you're using .38 & in the other thread .64 ?
undupit
Post by undupit »
therube wrote: 04 Feb 2025, 00:17 To be clear, you're getting both 380's & 440's ?
I can't remember.
Error 440 is not reproducible: sometimes it gives the error, sometimes it doesn't.
For error 'mTScrollContainer: Run-time error '440': Automation error', in AllDup 4.5.38 PE, Win10, GPT says:
Examples of effective fixes:
# Ensure all mTScrollContainer access happens on the UI thread, and nowhere else.
# Defer UI updates (queue them, throttle them, or batch them) instead of calling into the control during the comparison loop.
# Separate work and UI completely: do the comparisons first, then update the UI afterward.
I don't know if GPT is correct. I know for a fact that it's often wrong.
undupit
Post by undupit »
Now, I think that error 440 (almost?) always comes after error 380.
